Activity Forums Blackmagic Design DVCpro25 from Mac to Pc
  • DVCpro25 from Mac to Pc
    Posted by Andy Bay on February 13, 2008 at 12:49 pm
    Hi!
    I’m really struggling:
    We captured DVCpro25 footage with Final Cut Pro using Blackmagic DeckLink. Now we need to get the footage to a pc for editing. We managed to transfer the files to the pc using MacDrive software, but the Quictime player on the pc is giving a missing codec error. Premiere is just showing us a white screen, allthought the sound is playing. Is there any way to get the footage captured on a blackmagic card on a mac to work on a pc?
    Please help me with this as the deadline is closing up on me :/
    ANY help will be higly appreciated! Thank you!
    Andy Bay replied 18 years, 7 months ago 2 Members · 4 Replies
  • Craig Service
    February 13, 2008 at 7:10 pm
    A round-about fix may be to re-export the clips in Compressor using the DV NTSC settings in the Standard Definition folder. I would do a test with a short clip.
    Also, have you loaded the Blackmagic codecs on the Windows system?
    Good luck.
  • Andy Bay
    February 14, 2008 at 7:49 pm
    Hi!
    Thanks for your reply!
    We have installed the Black Magic codecs on the PC also. I searched some more in the web and I think now that the issue is related to the specific quictime files the Mac makes. After installing a trial version of DV Film’s Raylight plugin I was able to view the quictimes on he PC.
    I’m looking for a solution in which I don’t have to purchase additional software though. That’s why I’m interested in your suggestion to export to DV. But would I loose quality if I did that?
  • Craig Service
    February 16, 2008 at 6:53 pm
    Quality loss should be negligible.
    If you are concerned you could recapture via firewire and bypass the Decklink. Make sure you select Apple’s DV codec.
  • Andy Bay
    February 16, 2008 at 8:42 pm
    If only I could use firewire! :/
    The camera is an old Igekami so there is no such port on it. We capture using Black Magic together with a dvcpro deck.
    So there is really no way to render the footage out from Final Cut Pro in a lossless format that a pc understands? 🙁
