Activity Forums Adobe Premiere Pro DVCPRO100 capture not available????
  • DVCPRO100 capture not available????
    Posted by Adam Elder on February 25, 2008 at 5:07 pm
    I am trying to capture footage from HDCAM as DVCPRO100, since I do not have a high speed disk available. This is what we have always done on Final Cut Pro, but it seems to not be available as a capture setting in Premiere. I looked at the documentation, which states that it is compatible but does not come natively with the software. Where do I find an update to be able to do this – if I even can? If this is not the case, what other options do I have for recording 1080i 60p footage over SDI? The lowest (disk writing speed) option I have is 8-bit YUV 4:2:2, which is still too fast for my drive – as it crashes after 8 seconds. Thanks in advance
    Adam Elder
    323-251-7068
    adam@adameldermedia.com
    “There is no greater joy than soaring high on the wings of your dreams, except maybe the joy of watching a dreamer who has nowhere to land but in the ocean of reality” – despair inc.
    David Dobson replied 18 years, 6 months ago 2 Members · 1 Reply
  • David Dobson
    February 27, 2008 at 12:22 am
    What kind of capture card are you using – doesn’t it have capture options? PPro only does DVCProHD natively if it’s in the P2 format.
