DVCPRO to an 8-bit uncompressed – NONE or LOWER?
Hello
Got a DVcam 30 min program with many livetype graphics – the seq is edited on a DV/DVCPRO-NTSC 720×480 timeline…so I am planning on transferring the final cut to an uncompressed 8-bit timeline for Compressor to make MPEG2 (DVD), for the graphics and text benefit.
I know the DVcam footage will not benefit…but question is should I make all my livetype graphics with NONE field dominance (under properties in LT) and should I make the uncompressed 8-bit timeline NONE as well? Or can I just leave all at lower field settings, both in LT and the 8-bit timeline and get the sought after results – ie, clearer/better text?
What to do re: this scenario, while not disrupting lower field on the DVcam footage.
K
