Activity Forums Adobe Premiere Pro dvcpro tape capture
  • dvcpro tape capture
    Posted by Miss2z Miss2z on May 29, 2007 at 8:21 pm
    I capture video footage off of a Sony DSR-11 DVCAM deck. I’ve always used either DVCAM tapes or mini-DV tapes. However, a client gave me a DVCPro tape to capture from. The tape plays on the deck, since I can see it in my external monitor, but it’s not playing through the capture window of Premiere Pro. I tested my Sony DVCAM tapes and they are capturing fine. Is there a setting in Premiere Pro I should know about in order to capture from a DVCPro tape?
    miss2z
    Miss2z Miss2z replied 19 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    May 29, 2007 at 9:21 pm
    If I am not mistaken, Premiere Pro does not support capture from a DVCPro tape.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Miss2z Miss2z
    May 29, 2007 at 10:12 pm
    You have got to be kidding! Why?! How will I get this footage into the editing program? All this stuff is already logged on paper with the timecode, so it’s not like I can just dub it onto DVCAM tapes.
    miss2z
  • Hhv_pro
    May 29, 2007 at 10:56 pm
    That’s PPro. It doesn’t support any of the DVCPro50/HD format. If you are considering a uncompressed capture card for DVCPro, then be sure to check it out before buying it. Make sure it does what you expect it to do with PPro.
  • Blast1
    May 30, 2007 at 3:49 am
    [miss2z] “You have got to be kidding! Why?! How will I get this footage into the editing program?”
    Problem is DVCpro is a proprietary format and Premiere has to licence it from competitors.
    You will have to get a DVCpro codec to use the footage in Ppro, Raylight will do DVCpro50 and DVCproHD in Premiere, I don’t know if it will do DVCpro25 though, there are other DVCpro25 codecs on the web.
    Also I don’t think DVCpro25 will playback in a DSR-11 over firewire correctly.
  • Miss2z Miss2z
    May 30, 2007 at 3:58 am
    I read that PPro 2.0 can take in DVCPro footage.
  • Blast1
    May 30, 2007 at 5:02 am
    [miss2z] “I read that PPro 2.0 can take in DVCPro footage”
    This pdf lists formats for Ppro 2, note interface, hardware, and codec requirements for certain formats.
    https://www.adobe.com/products/premiere/pdfs/premiere_pro_formatguide.pdf
    https://www.mainconcept.com also has DVCpro codecs
  • Miss2z Miss2z
    May 31, 2007 at 5:11 am
    thank you. that was quite helpful.
    miss2z
