Activity Forums Adobe After Effects dvcpro on pc?
  • dvcpro on pc?
    Posted by Eugene Perepletchikov on August 31, 2006 at 12:25 pm
    Hello bovines
    I have already run a search and I know that its not looking good for me, but maybe someone has found a work around. I had footage captured on a mac as a quicktime with the dvcpro codec. These quicktimes do not run on my pc at home. Is there any way to get around this without reexporting the footage on a mac with something like the animation codec?
    Cheers
    Jason Rouleau replied 20 years ago 4 Members · 5 Replies
  • Nicholas Toth
    August 31, 2006 at 1:41 pm
    Just had the same problem. Wound up batch converting using squeeze in OSX. Sorenson 3 codec = very good stuff
    Or you can buy RAYLIGHT (https://www.dvfilm.com/) which is a codec converter thing. (I’ve never used it so I’m not saying buy it..its just rumored to solve the promblem)
    I was at a shoot last night and the sound guy told me that he was working on a project the other week where there was no problem with the P2 cards and importing the data into the PC environment. NO IDEA why it worked then, and it hasn’t worked with me or you.
  • Jason Rouleau
    August 31, 2006 at 6:49 pm
    I faced a similar situation.
    If you want to transfer Quictime DVCpro footage from MAC to PC with lossless quality, use the Sheer codec.
  • Eugene Perepletchikov
    August 31, 2006 at 10:44 pm
    Thanks for your responses guys. Just as I thought… Hey Jason, the Sheer codec, is that one you have to purchase or is it already an option in Quicktime 7 Pro, AE or FCP? Regardless, animation should be fine as it is lossless right? By the way this is dvcpro50 footage, nothing to do with the p2 HD stuff.
    Cheers
  • Majorasshole
    September 1, 2006 at 3:57 am
    look for the ACE mega codec pack
    install it and your pc media player will play everything
  • Jason Rouleau
    September 1, 2006 at 6:14 pm
    Ya sheer costs about 150$ I believe, but you can get a 20 day free trial.
    Its a good alternative to Animation cause its compression scheme is AWESOME, it creates super small files compared to Animation. In my opinion its the codec of choice for your situation
