Activity Forums Apple Final Cut Pro Legacy DVCPRO importing (DV50 vs. Uncompressed)
  • DVCPRO importing (DV50 vs. Uncompressed)
    Posted by Brian Pitt on September 20, 2005 at 1:23 pm
    Does anybody have any input on the following?
    I am going to be editing a bunch of stuff on DVCPRO in Final Cut. I am new to the format and had a few questions:
    What is the best way to import for the highest end result? (firewire vs. capture card)
    Is there a way to import compressed, make edits, and then re-import uncompressed for end result?
    Any tips or advice on importing DVCPRO 50 would be very helpful. thanks!
    NeutaMac
    Al replied 21 years ago 7 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    September 20, 2005 at 2:49 pm
    I think I’d just stay as native as possible… so capture via FireWire or SDI as DVCPRO50, and edit away…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Roth weiss
    September 20, 2005 at 3:01 pm
    There is zero benefit to you capturing uncompresssed. DV50 captured to hard drive via firewire is bit for bit what is recorded on tape, and in addition, audio and timecode are captured at the same time via the same cable. And, 250gb hard drives sell for $120 now — thats space for well over 100 hours of DV50. Why would you even think about capturing lo-res???
  • Brian Pitt
    September 20, 2005 at 3:05 pm
    Thanks. I didn’t realize you can fit that much footage onto the hard drive. I purchased a 1TB G-raid drive, so I shouldn’t have problems. thanks again!
    NeutaMac
  • Tony
    September 20, 2005 at 3:50 pm
    The benefits of capturing uncompressed would be see in complex color correction or keying sequences.
    If you have a video card such as AJA kona or Kona 2 you can capture to the mac in firewire and later output via SDI to record to digi beta or other format.
    Tony Salgado
    Tony Salgado
  • Walter Biscardi
    September 20, 2005 at 4:00 pm
    [Brian Pitt] “Thanks. I didn’t realize you can fit that much footage onto the hard drive. I purchased a 1TB G-raid drive, so I shouldn’t have problems. thanks again!”
    Just as a reference, I cut 7 episodes of a show for broadcast (22 minutes each) via DVCPro HD and with full corrections, filtering, etc and ready for mastering it all came to less than 400GB.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Dan Riley
    September 20, 2005 at 9:15 pm
    Well, if you don’t have a capture card and a bunch of drives for a RAID
    then do it all native firewire. Your actual footage from your DVCPRO
    tape will look the same whether it’s edited on a DV/DVCPRO timeline
    or an uncompressed timeline. However, you can get better looking titles,
    keys and graphics with a higher rez codec other than DV/DVCPRO.
    Either DVCPRO50 or uncompressed 8 bit or 10 bit is best for your finished show.
    My workflow is to offline at DV/DVCPRO, inputing our DVCPRO
    footage via our Aurora Pipe Studio card via SDI. Then for the
    finished show I uprez to 10 bit uncompressed.
    Dan
  • Al
    September 21, 2005 at 8:31 am
    I have a question about this : I’m just testing some captures via Firewire on a AJ-SD930 via Firewire, and the footage looks extremely “DV” whenever I take a look at the individual channels. The FG contours are extremely crunchy.
    It was my understanding that by sampling at 4:2:2 the DVCPro codec was much better for keying…
    What could I be doing wrong here?
    Alex
  • Al
    September 21, 2005 at 2:50 pm
    Also, sorry to repost, but I didn’t mention I’m shooting in 25p, not 50i. Is there a better setting for keying? Does FCP have to know about this setting when capturing?
    Alex
