Activity Forums Adobe After Effects DVCPro HD/ProRez Colorspace or Gamma CS3 PROBLEM!
  • DVCPro HD/ProRez Colorspace or Gamma CS3 PROBLEM!
    Posted by Scott Brignac on September 3, 2007 at 5:11 pm
    Ok. I’ve searched around and cannot find anyone dealing with this problem and I desperately need some help.
    My workflow is DVCPro HD 1080i. Whenever I bring this footage into AE CS3, its giving me this most annoying problem: Whenever I render, or just do a RAM preview, it darkens my footage considerably. I’ve tried using color management and nothing changes what is happening. So does it have to do with Gamma? What could cause such a thing?
    I brough in the same footage to AE7 with no problem. But I’m on an Mac Pro intel, and would like to use my newly purchased upgrade.
    Here is a link to see what I’m talking about:
    AECS3 Problem
    Any help is much appreciated.
    Scott Brignac
    brignac.tv
    Mark Jalson replied 18 years, 10 months ago 3 Members · 6 Replies
  • Scott Brignac
    September 3, 2007 at 5:13 pm
    I forgot to mention that I recompressed the footage to ProRez HQ and had the same problem.
    Scott Brignac
    brignac.tv
  • Brendan Coots
    September 4, 2007 at 4:14 pm
    If anything, I would guess that maybe it is the difference in color management between Quicktime and everything else. Have you been viewing the footage in Final Cut Pro (or similar) for these comparisons, or are you comparing the AE renders to the original footage in Quicktime? QT has some odd gamma issues, and while I’m not sure what the particulars are you may pull both clips into an editing app to make sure it isn’t quicktime giving you problems.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Scott Brignac
    September 5, 2007 at 1:51 am
    Footage looks fine in FCP and quicktime. It only happens when I render or RAM preview in AE CS3.
  • Mark Jalson
    September 11, 2007 at 8:55 am
    Same problem here, i’ve tried selecting different color space and clip otions in AE with no solution. With previous version of AE i had no gamma problem too.
  • Scott Brignac
    November 4, 2007 at 3:58 am
    Mark,
    Have you ever figured this out?
  • Mark Jalson
    November 4, 2007 at 3:14 pm
    yes, in the render queue just set the comp to be rendered in RGB. Sorry i’m not at work so i can’t be more precise.
