Activity Forums Apple Final Cut Pro Legacy DVCPRO HD/HDV color space?
  • DVCPRO HD/HDV color space?
    Posted by Grant Cheney on March 11, 2008 at 9:37 pm
    I’m having a color space issue. Hopefully someone has an answer. We have a HD digital cinema theater where I work. We play our HD films on a QuVis Cinema player. The films that we import from HDCAM tapes look great, good color and brightness.
    However we produce our own HD films on the HVX200 or a Sony HDV camera. I edit in Final Cut Pro under the native HD format (i.e. DVCPROHD or HDV), color monitored and corrected.
    I send the finished project to the theater using this workflow:
    -I drop my DVCPRO HD finished product into a new sequence which is 1920×1080 / square / uncompressed 8-bit
    -I render this and export the sequence as indvidual targas
    -the in QuApps (QuVis’s cinema file transcoder) I make the frames into a playable digital cinema file.
    Everything works great however the films look at least 2 stops darker in our theaters than how they were shot. The only thing that makes them look better is some slight gamma correction, but even that looks a bit off.
    Does anyone know where my color space problem is? Is it the step from compressed HD to 8-bit uncompressed? 709 or 601 issues? I’m kinda lost. Next step is to call QuVis.
    Any help would be great. Thanks.
    -g-
    Mac Power PC G5 – OS X 10.4.11 – FCP6 – After Effects CS3 – Panasonic HVX200
    Grant Cheney replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
