Activity Forums Apple Final Cut Pro Legacy DVCPRO-HD720p60 —- Help!
  • Manicboy
    August 15, 2007 at 3:08 pm
    Oh yeah, duh. You are correct sir. But I can’t really afford any video cards right now unfortunately.
  • Manicboy
    August 15, 2007 at 3:11 pm
    I appreciate the advice guys, thanks so much! I will try the single FW800 drive, and see if that works. Otherwise, I may stripe two internal drives … and use the FW800 as backups.
    Best Regards, Jesse
  • Manicboy
    August 16, 2007 at 6:59 pm
    I probably should have mentioned that I’m trying to do a multi-cam project edit. You think that’s probably why the FW800 drive is too slow? I might just go and buy a couple SATA drives and stripe ’em, see if that works. It worked BETTER on one internal atleast, maybe the raid will help.
    Jess
  • Jeremy Garchow
    August 16, 2007 at 7:09 pm
    [ManicBoy] “You think that’s probably why the FW800 drive is too slow?”
    Yes, most definitely.
Page 2 of 2
