Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD to SD previews
Posted by Matthew Mcnulty on June 22, 2007 at 8:13 pmhave a client that wants to see “dailies” of her dvcpro hd 1080i/60 clips… should i just drop hd stuff into a sd sequence, output self contained QT… or let compressor take a whack at it… dvd is the method for delivery to her… ???
or perhaps a alternate method for downconvert??
Rich Rubasch replied 19 years, 3 months ago 5 Members · 7 Replies -
Walter Biscardi
June 22, 2007 at 8:16 pmGet a Kona card and a DVD Recorder. Kona downconverts the HD to SD in realtime and the DVD Recorder records in realtime. You’re done.
We have a Panasonic DVD Recorder and it works fantastic for this very purpose.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Shane Ross
June 22, 2007 at 8:59 pm[walter biscardi] “Get a Kona card and a DVD Recorder. Kona downconverts the HD to SD in realtime and the DVD Recorder records in realtime. You’re done.
We have a Panasonic DVD Recorder and it works fantastic for this very purpose.”
I do EXACTLY the same thing Panasonic DVD Recorder and all.
Shane
Littlefrog Post
http://www.lfhd.net -
Shane Ross
June 22, 2007 at 9:37 pm[Mowbray] “the lhe will do his? let me RTFM”
ABSOLUTELY…I have the LH.
Just set the secondary output to downconvert in the AJA Control Panel…and connect it to the DVD recorder via Composite. Or Component if it is fancy-schmancy.
Shane
Littlefrog Post
Shane Ross
June 22, 2007 at 10:16 pmYou’d need a Black-Magic HD card for this. A standard def card cannot output a high def sequence.
Shane
Littlefrog Post
Rich Rubasch
June 23, 2007 at 3:15 amHey all….can’t you just take the composite out of the deck straight into a DVD recorder? I do it all the time, with and without window time code. It doesn’t tie up my Kona card system either. Isn’t that easier?
Rich Rubasch
Tilt Media
