Activity Forums Apple Final Cut Pro Legacy dvcpro hd to sd conversion problem
  • dvcpro hd to sd conversion problem
    Posted by Carlos Cidre on June 15, 2010 at 11:13 pm
    hey everybody,
    so here’s my problem.. i edited this spot as dvcprohd 1080i60 29.97… just how it was shot.. everything went smoothly but now i need to make an sd version.
    i have a blackmagic extreme card and i was planning to convert the footage to our usual sd digibeta layback format blackmagic uncompressed 10 bit 29.97. (i have to lay this to tape)
    so i exported the footage “as is” from my hd sequence and placed it on my bm uncompressed 10 bit sequence and resized to do a center cut. i’m getting this very noticeable flicker with movement on my ntsc monitor… when i import the clip into fcp a shift fields filter is added automatically but none of the different settings seem to help.
    i tried converting to uncompressed 10bit in compressor but not much difference was achieved… is there a proper way to do this conversion?
    thank you in advance..
    Shane Ross replied 16 years, 3 months ago 2 Members · 1 Reply
