Activity Forums Apple Final Cut Pro Legacy DVCPro HD rendering out weird
  • DVCPro HD rendering out weird
    Posted by Jordan Woods on September 8, 2006 at 5:34 pm
    I have a 720p DVCPro HD timeline that I want to pull stills from. this was shot 16×9 and for some reason I cannot get stills to come out at the same ratio, it always pulls them 4×3 and stretches the image… yea, i can go into photoshop and resize, but time consuming if you have a ton of stills to pull. The other thing I get is a square image on “make self-contained” quicktime, with current settings a.k.a 720p dvcproHD. is there a check box i’m missing here, or some other way to go about this? thanks,
    jordan
    Noah Kadner replied 20 years ago 3 Members · 2 Replies
  • Jeremy Garchow
    September 8, 2006 at 5:42 pm
    How are you exporting the stills? Are you suing quicktime conversion? If so, set the size to 1280×720.
  • Noah Kadner
    September 8, 2006 at 6:10 pm
    This is totally normal- in FCP the clips are being stretched automatically for proper viewing but the still output you’re seeing is the most native form. Resizing in Photoshop can be setup as an Action if it gets tedious or Jeremy’s way would do it too.
    Noah
