Activity Forums Apple Final Cut Pro Legacy DVCPRO HD Playback Issues on a tricked-out Macpro?
  • DVCPRO HD Playback Issues on a tricked-out Macpro?
    Posted by Lisa Rolley on April 9, 2008 at 7:24 pm
    Hello,
    Today I transferred over a project from one of the edit suites at my job onto my desk FCP setup and it wont playback – dropped frames!
    The edit suite has a single 8core MacPro with 4 TB of RAID storage – playback was totally fine – mind you I have a lot of time lapse footage sped up
    Now at my desk I have a single 8core MacPro with 500GB of edit storage SATA internal drive and now its a total drop frame playback nightmare.
    What should i do here? The project is all P2 footage so the sequence settings are: DVCPROHD 720P60
    Any advice people might have would be great
    thank you much
    Lisa Rolley
    John Kaley replied 18 years, 5 months ago 4 Members · 11 Replies
  • 11 Replies
  • Chris Borjis
    April 9, 2008 at 7:56 pm
    I take it the timeline has more than a single layer of video?
    you will have to adjust your realtime settings, i think
    it is near the timecode on the left side of the sequence/timeline.
    play with it until it works.
  • Lisa Rolley
    April 9, 2008 at 8:12 pm
    Sorry I forgot to mention that I have everything set to Dynamic as it recommends but still playback issues continue…i am hoping i just don’t understand one of the other recommendations and that someone can walk me through getting this puppy to playback.
  • Shane Ross
    April 9, 2008 at 8:28 pm
    [lisa rolley] “Now at my desk I have a single 8core MacPro with 500GB of edit storage SATA internal drive”
    Is this a separate drive from the main OS drive? As in you have TWO drives, one for the operating system and one for media? How is this drive formatted?
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Lisa Rolley
    April 9, 2008 at 10:50 pm
    its a 2nd internal drive where only media and projects for FCP live apps and everything else 9OS) are on the other Hard Drive.
  • Shane Ross
    April 9, 2008 at 10:53 pm
    And how is it formatted?
    Shane
    http://www.LFHD.net
    Read my blog!
  • Lisa Rolley
    April 10, 2008 at 12:45 am
    hey shane
    i am not sure how it is formatted to be honest – how would i figure that out?
  • Shane Ross
    April 10, 2008 at 7:46 am
    Open the Disk Utility and use that.
    Shane
    http://www.LFHD.net
    Read my blog!
  • Lisa Rolley
    April 10, 2008 at 1:29 pm
    Hello,
    so this is what it says when i have the 2nd drive highlighted in disk utility:
    Disk Description :ST3750640NS Media
    Total Capacity :698.6 GB (750,156,374,016 Bytes)
    Connection Bus :Serial ATA 2
    Write Status : Read/Write
    Connection Type :Internal
    S.M.A.R.T. Status : Verified
    Connection ID : “Bay 2” Partition Map Scheme : GUID Partition Table
    Mount Point : /Volumes/2nd Drive
    Capacity :698.3 GB (749,812,400,128 Bytes)
    Format :Mac OS Extended (Journaled)
    Available :260.5 GB (279,673,114,624 Bytes)
    Owners Enabled :Yes
    Used : 437.9 GB (470,139,285,504 Bytes)
    Number of Folders : 352 Number of Files : 6,594
  • Shane Ross
    April 10, 2008 at 2:42 pm
    [lisa rolley] “Format :Mac OS Extended (Journaled)”
    See that…FORMAT. SO it is formatted properly.
    Well, as of now I am stumped, because it is tough to do this when not in front of the computer in question. How about trying a brand new project with this media. Does it work then?
    Shane
    http://www.LFHD.net
    Read my blog!
  • Chris Borjis
    April 10, 2008 at 6:00 pm
    Try repartitioning WITHOUT journaling.
    its my understanding you can squeeze a little more performance out of it that way. Besides I’m pretty sure media disks should not be journaled anyway.
