Activity › Forums › Adobe After Effects › DVCPRO HD picture degrades in SD widescreen composition
Posted by Itamar Kool on August 31, 2009 at 2:02 pmI use DVCPRO HD 720p footage in a PAL widescreen comp. I scale it down to 51 percent enad move it. It looks all blocky. But the quick time file is sharp and OK. What am I doing wrong??
Adolfo Rozenfeld replied 16 years, 8 months ago 2 Members · 12 Replies -
Itamar Kool
August 31, 2009 at 4:03 pmJust to make sure: settings are all set to full quality and best settings. Graphics are sharp, live footage looks blocky, even with all effects off.
Kool En De Anderen
MAC Pro 8 core/OS 10.5.7/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
http://www.koolendeanderen.nl -
Adolfo Rozenfeld
August 31, 2009 at 5:32 pmAre you sure it’s not the draft-quality preview you get when you enable Pixel Aspect correction?
Adolfo Rozenfeld · Adobe
Itamar Kool
August 31, 2009 at 5:41 pmYes, it is also viewable on my video monitor. Also rendered it and the problem is in the rendered movie as well. Looked in the interpret footage window and there too every setting looks the way it should. It’s so strange
Kool En De Anderen
Itamar Kool
August 31, 2009 at 5:43 pmOne more thing: I put the footage in a DVCPRO HD 720 composition. Same problem
Kool En De Anderen
Adolfo Rozenfeld
August 31, 2009 at 6:01 pmDo you have a small sample clip you could upload to a file hosting service?
Itamar Kool
August 31, 2009 at 6:11 pmYes, tell me where I should upload it too. I can also put it on my idisk and send you a link
Kool En De Anderen
Adolfo Rozenfeld
August 31, 2009 at 6:28 pmYes, the iDisk link should be fine.
Send it to arozenfe@ the company I work for.comAdolfo Rozenfeld · Adobe
Itamar Kool
August 31, 2009 at 6:35 pmI’m doing it with yousendit. I guess you work at adobe….
Kool En De Anderen
Adolfo Rozenfeld
August 31, 2009 at 6:36 pmYes, and I get a ton of spam for posting my e-mail address everywhere 🙂
Itamar Kool
August 31, 2009 at 6:42 pmMeanwhile I found a workaround. I exported the clips from FCP in Pro Rez 4:2:2 and now they look OK in AE
Kool En De Anderen
