Activity › Forums › Adobe Premiere Pro › DVCPRO HD P2 PPro CS3 Settings Question
  • DVCPRO HD P2 PPro CS3 Settings Question
    Posted by Matthew Griffin on April 11, 2008 at 6:44 pm
    I….really need some help. I’m used to solving any problem you can sling at me in FCP (even hacked the program to fix pull in issue a few years ago). On Premiere CS3 I feel like all of the clear control options are withheld from me.
    I am editing a feature film shot on the Panasonic HV200E PAL camera. I’m editing on an XP 32-bit system that has a Blackmagic Intensity Card and a monitor with a HDMI-in (currently a large, pretty, object-d-art until I figure out how to get the card to work)
    The P2 viewer lists this media as:
    DV100_720/50p
    Pulldon 2:2
    Aspect Ratio: 16:9
    Audio Sampling: 48k/16bit
    When I create a P2 DVCPRO HD 720p/50fps default project I have to render all playback (material plays back beautifully in Source monitor for non-Blackmagic formats: blackmagic options does this strange purple “golden mean” spiral pattern)
    When I create custom 25fps version everything seems peachy, but I’ll be darned if I can export an H.264 file looking halfway decent even at High Profile and a healthy data rate.
    Even aside from any of these issues, what kind of project settings do you seasoned pros suggest for me to work on this sequence? I have 140 cards to bring online soon….I’d hate to pick the wrong thing and have to do them all over again!
    Thanks so much in advance. It has been years since I have ended up this frustrated before a project starts.
    Matt
    Matthew Griffin replied 18 years, 5 months ago 2 Members · 3 Replies
  • Vince Becquiot
    April 12, 2008 at 5:46 am
    First, I’m in NTSC land, and second that may be a good question for the HVX forum as well.
    As far as I know Premiere doesn’t support 50P P2 native, which would explain the render line. I never shot 60P P2, being the NTSC equivalent, but I’m guessing I would get the render line as well.
    For your export, try unchecking frame blending and see if that help, I find it to cause jitter in my P2 exports.
    That’s all I can offer, I hope others will shime in.
    Vince
  • Matthew Griffin
    April 12, 2008 at 5:52 am
    Thanks, this is helpful. Any one else have some thoughts to contribute?
    Matt
  • Matthew Griffin
    April 14, 2008 at 1:55 pm
    Perhaps a simpler question would be to just ask if I should force myself to use the default p2 dvcpro-hd 720p50 option even though it red-bars my media when I drag it to the timeline. I wonder if I would have better luck with outputs this way than my custom-rolled 25fps timeline.
    And if any of you P2 premiere pro cs3 folks could direct me to resources/sites/wikis/etc where I could research this question further that would be helpful! (I’ve certainly done my share of googling and reading — I’d just like recommendations for sites that proved helpful to you folks!)
    Thanks again,
    Matt
