Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD on Powerbook
  • DVCPRO HD on Powerbook
    Posted by Mike Schrengohst on March 2, 2006 at 3:21 pm
    I have a 17″ Powerbook, one gig ram, 7200 Internal drive.
    I have the HVX-200 and have been trying to
    edit in 1080i. I do an easy-setup to DVCPRO HD 1080i.
    The P2 file import and makes the .mov file
    the .mov file is there but it wants to render.
    I have been back and forth looking at
    sequence properties and noticed it
    will be changed from time to time.
    I have been able to see one clip
    I have shot but cannot figure out all the
    exact settings I need .
    Mike Schrengohst replied 20 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    March 2, 2006 at 3:27 pm
    Make sure you’re not using Sequence 1 from your new project. That would retain the old settings from when you first launched FCP. When you went into Easy Setup and changed over to DVCPro HD 1080i that would affect every new Sequence you would create from that moment forward.
    When I use Easy Setup in a new project, I immediately trash Sequence 1 in the Browswer and create a new Sequence.
    If that doesn’t work, then you have a mismatch between your footage and the Easy Setup you’re using.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Mike Schrengohst
    March 2, 2006 at 3:41 pm
    Thanks Walter I will look at that.
    Plus I am trying both 24PN and 24p footage from the HVX.
    Is FCP 5 able to use the 24PN footage without rendering?
    All the clips will PB fine in QuickTime.
  • Steve Eisen
    March 2, 2006 at 4:14 pm
    You should consider shooting in 720/24p. It all depends on the look you are going for.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Shane Ross
    March 2, 2006 at 5:43 pm
    [Mike Schrengohst] “Plus I am trying both 24PN and 24p footage from the HVX.
    Is FCP 5 able to use the 24PN footage without rendering?”
    Absolutely….BUT…it depends on your sequence settings. If they are for 24P, which is 29.97, right?, then you will have to render. But if your sequence settings are 720p24 (23,98) you won’t have to render the 24pn, but rather any other format you add. That is the nature of the beast. I am mainly working with 24PN footage, but have 60P footage that we intended for slo motion work, and also just to cut at normal speed. When I drop it into the timeline, I have to render it, because the settings are different.
    Why aer you shooting two different frame rates? Stick to one if you can. We shot 60P for the purpose of slowing to 23.98 in post.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Mike Schrengohst
    March 2, 2006 at 7:10 pm
    “Why are you shooting two different frame rates? Stick to one if you can. We shot 60P for the purpose of slowing to 23.98 in post.”
    Experimenting with the look first and foremost.
    I need to get a larger external monitor for my
    PB. We are being contracted to shoot some
    stock footage. The producer wants 1920x1080p
    so they will have the largest sell through.
    I have worked with them with the DVX for years.
    I just need to find a look they like and stick
    with it.
  • Drizzt_g
    March 2, 2006 at 7:26 pm
    Mike, let us know your test results, wich one is the best for the PB. I have a 15″ PB and I had problems with some formats of HD.
  • Drizzt_g
    March 2, 2006 at 7:28 pm
  • Mike Schrengohst
    March 2, 2006 at 10:23 pm
    What kind of formats did you have problems with??
