Activity Forums Adobe Premiere Pro DVCPRO HD MOV video appears as white screen
  • DVCPRO HD MOV video appears as white screen
    Posted by Ivan Myles on August 3, 2013 at 5:24 pm
    I am working with DVCPRO HD footage. The files all look good except for one. In the problem file video appears white when imported to either Premiere Pro or After Effects CS6.
    The audio stream plays without issue. Any ideas on how to troubleshoot the video? The problem file is posted here, and its MediaInfo detail is listed below. All parameters other than file size are the same as the good files.
    General
    Format : MPEG-4
    Commercial name : DVCPRO HD
    Format profile : QuickTime
    Codec ID : qt
    File size : 18.0 GiB
    Duration : 22mn 2s
    Overall bit rate : 117 Mbps
    Encoded date : UTC 2008-10-20 20:10:22
    Tagged date : UTC 2013-08-03 14:13:16
    Writing library : Apple QuickTime
    ©TSC : 5994
    ©TSZ : 100
    Video
    Format : DV
    Codec ID : dvhp
    Duration : 22mn 2s
    Bit rate mode : Constant
    Bit rate : 97.8 Mbps
    Encoded bit rate : 115 Mbps
    Width : 936 pixels
    Original width : 960 pixels
    Height : 702 pixels
    Original height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 10 bits
    Scan type : Progressive
    Original scan type : Interlaced
    Original scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.482
    Time code of first frame : 00:00:00:00
    Time code source : Subcode time code
    Stream size : 15.1 GiB (84%)
    Encoded stream size : 17.7 GiB (99%)
    Language : English
    Tagged date : UTC 2008-10-20 20:21:45
    Color primaries : BT.709 / BT.709
    Transfer characteristics : BT.709 / BT.709
    Matrix coefficients : BT.709 / BT.709
    Ivan Myles replied 13 years ago 3 Members · 3 Replies
  • Shane Ross
    August 3, 2013 at 10:01 pm
    The QT dvcpro HD format that FCP uses is proprietary, so only computers with FCP installed can view them. You either need to convert to ProRes before bringing overcrowding the other system, or provide them the camera raw footage (if this is P2).
    Shane
    Little Frog Post
  • Tero Ahlfors
    August 4, 2013 at 10:55 am
    [Ivan Myles] “Bottom Field First”
    Huh?
  • Ivan Myles
    August 4, 2013 at 2:16 pm
    Thank you for the message. I was able to view the video in QTPro after downloading a DVCPRO HD decoder. Why would Premiere/AE (CS6-Win7) have trouble with one file but open six others without issue when all the files appear to be encoded the same?
