Activity › Forums › Adobe After Effects › DVCPRO HD i/o aspect wrong
  • DVCPRO HD i/o aspect wrong
    Posted by Joe Langenfeld on October 30, 2006 at 7:01 pm
    I am trying to import DVCPROHD footage into AE 7, comp it, and export to DVCPROHD for FCP 5. The footage is squished. I am using DVCPROHD 720 24P (23.98)…what should the settings be for render que to export the same format and aspect as I brought in?
    Joe Langenfeld replied 19 years, 11 months ago 2 Members · 2 Replies
  • Steve Roberts
    October 30, 2006 at 7:18 pm
    When you import it, see if it comes in as 1280×720 square pixels. If so, drag it onto the new comp button to make a matching comp.
    If not, try re-interpreting it as 1280×720, square pixels.
  • Joe Langenfeld
    October 30, 2006 at 9:21 pm
    Yes, I changed it to 1280…too bad the preset does not work…thank you!
