Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD frame size/resolution in FCP.
  • DVCPRO HD frame size/resolution in FCP.
    Posted by Quietlife on March 20, 2007 at 9:39 pm
    Hi.
    Our project is DVCPRO HD 720P 25. My question is about the frame size; in browser when looking imported DVCPRO HD 720P clips, frame size is described as 960×720. But that’s 4:3 resolution. Though the picture is 16:9. Aren’t all HD formats 16:9? Shouldn’t the frame size be 1280×720? The camera we are using is Panasonic AJ-HDX900E. And the CCDs are 1280×720.
    In sequence settings the frame size is also the same 960×720. And the pixel aspect ratio is 960×720.
    So can someone explain why isn’t the frame size 1280×720 and why? And since it’s not are we losing 1280-960=320 frames in width?
    Best regards
    Mikko Kujala
    1st Assistant Camera
    HD-Prodcution Oy
    Finland
    Jeremy Garchow replied 19 years, 6 months ago 5 Members · 5 Replies
  • Shane Ross
    March 20, 2007 at 10:38 pm
    DVCPRO HD is an ANAMORPHIC format. 12800×720 squeezed into a 960×720 frame. FCP unsqueezes it when you edit. And you’d need a proper 16:9 monitor to view it, or people will look tall and thin.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Walter Biscardi
    March 20, 2007 at 11:10 pm
    [Shane Ross] “VCPRO HD is an ANAMORPHIC format. 12800×720 squeezed into a 960×720 frame”
    And the same goes for HDV, anamorphic as well.
    Do NOT make any changes to the Easy Setup Capture and Sequence Presets or you’ll be rendering everything.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jeremy Garchow
    March 21, 2007 at 3:05 am
    Also, HD Cam gets recorded to tape anamorphically as well.
    It saves on bandwidth.
  • Marc Poirier
    March 22, 2007 at 12:02 am
    I don’t know if I should post this here or in After Effects, but here goes…
    I’ve exported a clip to be worked on in AE, in AE the clip shows as 1280 x 720… if I keep the same pixel aspect ratio, the image is distorded (too wide) since the comp is at 960×720….If I set the pixel aspect ratio on the clip to square then it fits the comp, but the comp is set to DVCPro 720, and the pixel aspect ratio is HDV/DVCPro HD anamorphic 16:9…. I need to bring that back into Final cut pro, should I go with square pixel ratio on my clips to get right after in FCP, or do I need to work in 1280 x 720 square all the way…
    thanks,
    Markyyy
  • Jeremy Garchow
    March 22, 2007 at 2:33 am
    You have failed to mentioned what codec you are working with in FCP. I can take an educated guess….but…
