Activity › Forums › Panasonic Cameras › DVCPro HD footage little “red lines” or data, pixel, etc. errors.
  • DVCPro HD footage little “red lines” or data, pixel, etc. errors.
    Posted by Fran Crow on August 11, 2010 at 11:42 am
    HI,
    I need some help here. In my last couple(maybe more) I’m seen in the Dvcpro Hd 720p60(different frame rate) footage shoot with my AG-HVX-200a, a little(short) and imperceptible couple of red lines, like some data or display error. I’ve seen for a time, but doesn’t bother me or disappear. I took one of my recent project to Color, but when the finish, I’m seen the “lines” more. It’s hard to describe the lines or error.
    I log and tranfer with final cut pro 6.0.6 and I’m working in the same source sequence. Here is a still capture of the problem: https://elcuervofilms.com/videos/sample.jpg
    Fran Crow replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    August 11, 2010 at 6:36 pm
    I’ve read posts about dirty contacts causing strange on-screen glitches. Try blowing out the P2 card sockets and the card’s contacts, to.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Fran Crow
    August 11, 2010 at 6:58 pm
    Don’t worry, I solved. Was like points red sometimes green, like corrupted data. I really don’t know how to solved. I throw to the trash the Color prefs file, try to render one of the clips, and reconnect it again, and solve. The thing that I notice was that if you don’t write a name for the files on the render destination directory, final cut could confuse with others clips render before from Color, like my case. For that, I have to reconnect one by one, cause I already do other thing to the timeline and I won’t do it again.
    But the bad data, never knows. I don’t think that is the camcorder, because the little color point I always see it on editing(after transcode). I will upgrade my FCP 6 to FCP 7, maybe is my system. Thanks anyway. If someone knows about it, please tell me.
