Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD export aspect ratio crazyness
Posted by Patrick Petersen on August 14, 2008 at 2:13 amSo, when I export a DVCPRO HD 720 30p timeline in Compressor or QT Compression to 320×240 (or any 4:3 aspect ratio), it elongates the picture, no matter what settings I change. I’ve tried to figure it out for a long time, and I’ve found pages that say it’s a bug, and that DVCPRO HD is really not 1280 x 720 and has weird (1.333) pixels … long story short, can I get correct aspect ratio via letterbox in a 4:3 frame size?
Patrick Petersen replied 18 years, 1 month ago 3 Members · 13 Replies -
Rafael Amador
August 14, 2008 at 4:07 amNo bug at all.
If You have a 16×9 picture and you want to show it in a 4×3 screen, you have two solutions:
– Crop the two sides of the 16×9. In this case the movie will fill the screen but you will lose part of the picture.
– Letter-boxing. You will see the whole of your picture with a black band on top and down.Open in FC a 8b-Unc 4×3 sequence (Progressive) and drop your DVCProHD movie on it. Resize to picture or let it letter-boxed. Export with QT conversion 320×240.
rafael -
Patrick Petersen
August 14, 2008 at 6:27 amNo way to get the desired results if the timeline is already DVCPRO HD. Because rendering all the time kind of sucks. There has to be a group of settings or compression that can add two simple bars to a 16:9 picture. But thanks for the advice, that’ll at least work for some projects! 😀
Jeremy Garchow
August 14, 2008 at 2:51 pmTwo options. Make a 16×9 aspect ratio (such as 640×360). No letterbox. It’s much cleaner.
or
Mess with the padding in the geometry tab. For example if you want a 640×480 with letterbox you have to do a bit of math first. 640×360 is a 16×9 image. So take 480-360 (which equals 120) then divide that by 2. 120/2=60. So add a pad of 60 pixels on the top and 60 on the bottom. You can preview this in the COmpressor window to make sure you got it right.
Jeremy
Patrick Petersen
August 14, 2008 at 5:28 pmYeah, that’s how we’ve been doing it. It just seems, from the different checkboxes and DVCPRO HD presets and all, that theres’s a more elegant, maybe less lossy way to do it. But yeah, buffers are how we’ve been doing it. What causes this? Because other formats letterbox fine with the right settings … Thanks, by the way, you guys all rock. Hard.
Jeremy Garchow
August 14, 2008 at 6:06 pmWell, DVCPRo HD is Natively 16×9 squeezed to 4×3. In roder to properly show the correct 16×9 aspect ratio, you are going to have to stretch it out somewhere. Compressor does a fine job of this.
Jeremy
Patrick Petersen
August 14, 2008 at 7:38 pmWell, if that’s the best way, it’s the best way! Thanks a bunch. Now, I am a little confused. You said it’s 16:9 squeezed into 4:3. My (probably way off) understanding was that it’s 4:3 (960×720) stretched to 16:9 (1280×720) by using rectangular pixels (1.333). These are probably dumb questions, but I’m self-taught so my knowledge is hardly textbook. Thanks again.
Jeremy Garchow
August 14, 2008 at 9:28 pmYou’re right. It’s a different aspect ratio. When it gets played back those rect pixels @ 1.333 get sqauhsed to square (1.778, which is 16×9)
Jeremy
Patrick Petersen
August 15, 2008 at 5:26 pmThen (bear with me here) how does the frame size (dimension) get bigger? If it’s 960×720 native, to become 1280×720, doesn’t something have to get stretched?
