Activity Forums Apple Final Cut Pro Legacy DVCPRO HD EXPERIMENT !
  • DVCPRO HD EXPERIMENT !
    Posted by Antonio Atzei on June 5, 2007 at 11:22 am
    Can set a new timeline in dvcpro hd as follows?
    I`ll use the same project i`m working on hdv(curious about the format)
    Can I leave all the settings related to frame size / pixel aspect ratio same as they are in hdv.. and change only compressor to DVCPRO HD 1080i50? Output will be sd dvd if i`ll evr mange to finish ! ha ha
    Thank you
    ciao
    Antonio
    BABALOTTI PRODUCTIONS
    SYDNEY
    POWER MAC G5 QUAD SYSTEM
    5.5GB RAM
    1 TB OF MEMORY.FCStudio
    Antonio Atzei replied 19 years, 3 months ago 2 Members · 4 Replies
  • Walter Biscardi
    June 5, 2007 at 11:27 am
    You will have to render the entire timeline so as long as you don’t mind losing all realtime playback, it should work.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Antonio Atzei
    June 5, 2007 at 11:39 am
    Walter txs
    do you mean that for as long as i work and do color until i`ll have the dvd I won`t be able to see it in real time? no prob
    and the settings in the timeline they have to respect the original format? changing only compressor to dvcpro hd?
    txs
    Antonio Atzei
    SYDNEY
    5.5GB RAM
  • Walter Biscardi
    June 5, 2007 at 11:58 am
    [Antonio Atzei]
    and the settings in the timeline they have to respect the original format? changing only compressor to dvcpro hd?”
    I have never tried this experiment so I assume that as long as the pixel aspect / frame sizes match exactly to DVCPro HD, then only changing the compressor to DVCPro HD should work. But I’ve never done this, we transcode to DVCPro HD in realtime during capture of HDV material.
  • Antonio Atzei
    June 5, 2007 at 12:34 pm
    Walter
    I can be the lab rat then!
    Is dvcpro hd 50 1280 x 1080 my footage is 1440 x 1080 can i downconvert even more?…. wow!
    txs a lot!
    ciao
    Antonio Atzei
    SYDNEY
    5.5GB RAM
