Activity Forums Apple Final Cut Pro Legacy DVCPRO HD direct capture to FCP question
  • DVCPRO HD direct capture to FCP question
    Posted by Robert Buncher on June 13, 2008 at 10:15 pm
    I plan to capture DVCPRO HD from an HDX900 directly to FCP 5 using capture now with the uncontrollable device setting. I realize that I will not have timecode.
    I plan on editing in DVCPRO HD with much exporting to After Effects for keying and other effects and then back to FCP. MY final output will be both HDCAM and DVD.
    My question is will the lack of timecode affect my workflow in a negative way? Since I am not doing an offline I think I should be OK.
    Is that correct?
    Bob
    MacbookPro 2.33 2 gb os 10.4.11
    FCP 5.1.4 Bootcamp XPpro
    Vegas DVRack Ultra 2
    Robert Buncher replied 18 years, 2 months ago 2 Members · 2 Replies
  • Shane Ross
    June 14, 2008 at 12:38 am
    Well…what if your hard drive fails? What if a clip goes offline for another reason? Then you are SOL…you will have to recapture and re-edit from scratch.
    Other than that, I see no adverse effects. Each clip will have timecode, but each one will start at 00;00;00;00 and not relate to your tapes. That’s all.
    Time code is a HUGE deal…IMHO.
    Shane
  • Robert Buncher
    June 14, 2008 at 10:21 pm
    Shane,
    Thanks for making me aware of these issues. Perhaps I could use the capture now function as a monitoring tool while shooting and later capture the tapes with time code.
    Bob
