Activity Forums Apple Final Cut Pro Legacy DVCPro HD deck
  • Posted by Max Prum on May 15, 2012 at 9:24 am
    I hope someone out there can help me with this quickly because I am at a loss.
    I am trying to capture DVCpro HD tapes shot in 1080pA24. Every time I capture there are drop frames and the audio goes out of sync. All night I wrestled with the capture settings and pull down removal because I thought that the audio drift was due to incorrect frame rate settings or something wrong with pull down.
    I tried capturing through firewire as well as the Kona LHI. I also tried capturing 1080pA24 and I tried doing the pull down after.
    Now I believe it is simply the drop frames that are throwing the sync off. Does anyone know how i can fix this? I tried cleaning the deck heads but no luck. What could be causing these drop frames?
    Max Prum replied 14 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 15, 2012 at 12:35 pm
    Most of the time, dropped frames are being caused by drive problems… what are you using as a scratch disk, and have you tested it’s write speed?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Max Prum
    May 15, 2012 at 1:46 pm
    Ugh your right. I finally (after about 12 hours) isolated the problem as a balky firewire port and a slow drive. It really shouldn’t have taken so long but I was so focused on thinking it was something I was doing wrong with the settings.
