Activity Forums Adobe After Effects DVCPRO-HD conversion?
  • DVCPRO-HD conversion?
    Posted by Nicholas Toth on January 27, 2007 at 8:35 pm
    Hey guys —
    So heres the deal. I imported a boatload of footage via P2 onto my FCP system, and i need to bounce it to a PC. If I batch convert it, what setting would be best comparable to the original DVCPRO-HD footage? Animation? Uncompressed? DVCPRO-HD footage isn’t all that big — I was thinking sorenson 3 may not look all that bad….
    Advice? Anyone run into this wall before?
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
    Nicholas Toth replied 19 years, 7 months ago 4 Members · 5 Replies
  • Iancorey
    January 27, 2007 at 9:38 pm
    If I’m not mistaken, you should just use the codec that’s embedded. In other words, a direct duplication onto your PC’s drive.
    Here’s what I’d do to make sure:
    Open FCP.
    Select a clip.
    Hit Command 9
    Look for the row that tells you the encoding.
    It’s something like HDV 720.
    DO NOT USE SORENSON 3! It’s Lossy.
  • Nicholas Toth
    January 29, 2007 at 12:38 am
    PCS don’t like DVCPRO-HD, unless you have the software, which I don’t have.
    I’m just looking for a decent codec!
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
  • Alexxx
    January 29, 2007 at 2:23 am
    I would use Quicktime with the PhotoJPEG codec at highest quality. No Alpha channel but by the sounds you don’t need it.
    Alex
    http://www.lightdrop.com.au
  • Kevin Camp
    January 29, 2007 at 6:21 pm
    if you’re going to effect it on the pc, i would use the animation codec… why lose any quality at this stage. then, for delivery, if you need to render to a specific codec compress it at that point.
  • Nicholas Toth
    January 30, 2007 at 4:30 am
    Good thing they’re short clips —
    I wound up just going out 4:2:2 uncompressed codec — yeah they’re a little big, but they still stream off a firewire 800 drive.
    MAN I wish this binary conversion process was easier…
