Activity Forums Apple Final Cut Pro Legacy DVCPRO HD codec problem
  • DVCPRO HD codec problem
    Posted by Andy Kachor on March 6, 2007 at 5:51 am
    I am unable to view quicktime files in the DVCPro HD 760p60 format on final cut pro v. 5.0.4
    Shot with Panasonic HVX
    I have a Powerbook G4, v. 10.4.8, 1 GHz processor, 512 MB SDRAM
    Get error message about using compression type without corresponding hardware card.
    any help would be appreciated
    thanks
    Gary Adcock replied 19 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    March 6, 2007 at 7:49 am
    Was it imported on a FCP system running a later version of FCP? If so, that’s why. There are newer DVCPRO HD codecs. Time to upgrade.
    Oh, and get more RAM. Suprised you can work with FCP with only 512MB RAM in your system.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Gary Adcock
    March 6, 2007 at 1:40 pm
    [Shane Ross] “Oh, and get more RAM. Suprised you can work with FCP with only 512MB RAM in your system.”
    thats the problem — the DVCPROHD codec needs 1G Ram to be able to load….
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • 13 Create COW Profile Image
    13
    March 6, 2007 at 2:22 pm
    your computer is way to slow for any format of HD if you want to use it to edit stick with DV
  • Andy Kachor
    March 6, 2007 at 8:26 pm
    How do I upgrade from final cut 5.0 to the latest version, do I have to re-install everything from scratch?
    thanks
  • Andy Kachor
    March 6, 2007 at 8:27 pm
    thanks
  • John Pale
    March 6, 2007 at 9:33 pm
    You need to go to Apple’s website and purchase the 5.1 crossgrade.
    You ship them your install disks and they send you new ones. The new disks will likely have the current version on it.
    (if not, you will just do the crossgrade install, then run Software update to get to the most recent point release)
    https://www.apple.com/universal/crossgrade/
  • Spotmen Inc.
    March 8, 2007 at 3:35 am
    Hello,
    The new FCP update installs a new codec for DVCPRO HD. An update should solve your problem.
    Cheers,
    PM
    http://www.spotmen.com
    Spotmen Studios Inc.
    15 N. Arlington Heights Rd
    suite #103
    Arlington Heights, IL. 60004
    https://spotmen.com/search/spotmen.html
    https://spotmen.com/search/spotmen_studios_inc.html
    https://spotmen.com/search/spotmen_studios.html
    https://spotmen.com/search/spotmenstudios.html
    https://spotmen.com/search/spotmenstudiosinc.html
  • Gary Adcock
    March 8, 2007 at 2:57 pm
    [Spotmen Inc.] “The new FCP update installs a new codec for DVCPRO HD. An update should solve your problem.”
    Just the UB version. not changed since FCP 5.1
    gary adcock
    Studio37
