Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD and FCP bit rates
  • Michael Gissing
    January 29, 2010 at 11:20 pm
    I think it is the difference between megabits and megabytes per second. Usually it is delineated by big M or small m.
    FCP doesn’t change the data on ingest so both rates are the same.
  • Matt Kerstein
    January 29, 2010 at 11:34 pm
    Thanks Mike..But Im still wondering..so 13MB/sec = 130mbps..that would be over the native data rate?
    Aloha & Mahalo from Maui
  • Shane Ross
    January 30, 2010 at 12:11 am
    DVCPRO HD 720p60 is 100mb/s. If you capture a lower frame rate, like 23.98, then the data rate is less…because you captured less frames.
    And the math isn’t straight even numbers. Just like 1MB isn’t 1000KB…it is 1024KB.
    Shane
  • Matt Kerstein
    January 30, 2010 at 12:39 am
    Bing!! The light just went on in my thick head! Thanks for the explanation Guys!
  • Arnie Schlissel
    January 30, 2010 at 5:20 am
    [Matt Kerstein] “13MB/sec = 130mbps”
    your school district must have taught the “new” math. 1 Byte= 8 bits, so in my school district 12.5MB/sec is 100mb/sec.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
