Activity Forums Adobe After Effects DVCPRO HD 720p60
  • DVCPRO HD 720p60
    Posted by Edward Nahapetian on March 20, 2008 at 11:29 pm
    Hello there, I have a project in final cut which was shot on DVCPRO HD 720p60, now I want to import in after effect to do some composing but I can not find any DVCPRO HD 720p60 format in composition settings. I do not want to change anything because I have to take it back in to the final cut. If I change only the frame rate in composition setting is it going to work or not?
    Any idea, need a help with this.
    Thanks Ed.
    Jason Jenkins replied 18 years, 6 months ago 2 Members · 2 Replies
  • Edward Nahapetian
    March 21, 2008 at 5:20 pm
    Hi Dave, I knew I could change it in render queues output module & I did, but the problem I came a cross was: I lost my lossless with alpha & I had a black background after rendering, any idea?
    Thanks Ed.
  • Jason Jenkins
    March 21, 2008 at 6:58 pm
    If you are rendering to DVCPro HD, that is the problem. DVCPro doesn’t support alpha.
