DVCPRO HD 720p60 import problem
I’m having some trouble here, fellas.
I bought a canon 7d about a week ago, recorded some footage at 1080p (29.97fps). Now, the 7d puts a quicktime h264 compression on the footage, which is difficult to edit with. So, I downloaded a program (MPEG Streamclip), which can convert the footage to DVCPro HD 720p60.
When I play the converted .mov, all is well – and it shows up as DVCPRO HD (720p60) in it’s info.
Problem is, when I import the footage into AE, it’s being read as 960 X 720. I open up the composition settings, and it confirms that. Also, the pixel aspect ratio is set at HDV 1080/DVCPro HD 720 (1.33).
It should be noted that this is not happening in Premiere.
Any thoughts?
