Activity Forums Blackmagic Design DVCPro HD 720p50 (960×720) on through decklink pro to sony SDI monitor
  • DVCPro HD 720p50 (960×720) on through decklink pro to sony SDI monitor
    Posted by Adam Howden on June 25, 2007 at 1:59 am
    Hi All,
    I’ve just shot a project in DVCPro HD 720p50 (960×720) and am having trouble getting it to playback on my Sony PVM 14″ CRT Monitor going through my Decklink Pro SD Card, does anyone have any thoughts on this, please help if you can client supposed to be coming over soon 🙂
    1 X Dual 2GHZ G5
    2.5 GIG RAM
    1 X Decklink Pro
    1 X UL3D SCSI CARD
    4 X SEAGATE 10K 136 GIG SCSI Drives Software RAID
    Final Cut Studio, AE 6.5, Adobe Creative Suite etc
    Michael Tauber replied 19 years, 2 months ago 4 Members · 4 Replies
  • Deleted User
    June 26, 2007 at 12:05 pm
    Hello Adam,
    What problem are you having? Is the footage displaying with wavy lines etc? It could be that t he progressive signal is not being picked up by the Sony monitor. You may have to do a tweak on the output to the monitor frequencey.
    Leo
  • Robin Erard
    June 26, 2007 at 5:40 pm
    I’have the same probleme,
    Under final cut (5.1.4), in dvcpro hd 720p50, I have an image, when I srub on the time line with the mouse, in pause, I have the image. But in playback, the image is fixed at the in point of reading, then at the end point when I stop the playback
  • Deleted User
    June 27, 2007 at 11:50 pm
    Hello Robin,
    This does sound very un-usual, I have not used DVCPRO HD, what connection does it link from? Is it SDI to your monitor from the Blackmagic?
    Have you tried a test with a Mini DV clip on a DV timeline to see if you get the same problem of the footage playbacvk buffering the first and last frame?
    It could be a issue where the project preset it not outputting the file correctly, I had a similar problem and re-installing Premiere fixed the problem.
    Leo
  • Michael Tauber
    July 5, 2007 at 1:21 pm
    What frame rate did you use?
    If it’s 25 fps then only a AJA card would help in FCP 5.1.x.
    With FCP 6 you can use the normal 720p50 output setting with BMD.
    If you shot 50p then you need to use a XML hack to get this working in FCP. Google for “720p50 xml” to find out more about it.
