Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD 720p24 bug – Walter?
  • DVCPRO HD 720p24 bug – Walter?
    Posted by Alan Okey on July 1, 2008 at 5:23 pm
    I’ve been searching the forums for any mention if this, but I don’t see anything recent.
    FCP has a render bug that’s driving me absolutely bonkers. The project is DVCPRO HD 720p24. I’m creating graphics in Combustion and exporting them as Quicktime movies with the proper compression settings. When the clips are imported and placed on the timeline they play just fine, no rendering required.
    Whenever the imported clips are altered within FCP, such as doing cross-dissolves, opacity ramps, adding a 3-way CC filter, etc. the rendered segments play back with a stuttering motion. Stepping through the rendered segments shows duplicate frames, hence the stuttering effect. It’s bizarre. The segments play back the same way both on the computer monitor and on the broadcast monitor (Sony PVM-20L5/1 fed by Kona LHe). As long as the imported clips are not altered, they play back perfectly. Quicktime Player reports the clips as having the proper frame rate, dimensions and compression settings.
    I’ve tried everything to get around the issue. I tried exporting my comps as image sequences, then importing the sequence folder into FCP (making the default still length one frame) and placing the nested stills on the timeline. The exact same thing happens. As long as there are no dissolves or superimposed tracks, the image sequence plays back properly. Exporting the comps from Combustion as Quicktime movies using different codecs (Animation, ProRes, etc.) doesn’t change the problem.
    The bug does not occur with any of the footage from the camera (DVCPRO HD 720p24 from an HVX-200). Cross-dissolving between the camera-originated footage works perfectly.
    I suspect that Quicktime is the culprit, but at some low level that is impossible to diagnose.
    Walter, I know you rely on a DVCPRO HD workflow for your projects. Have you run into this before?
    System specs:
    Mac Pro 2×2.66GHz dual core Xeon (quad core) / 2.5GB RAM / ATI X1900 XT / 2TB 4-drive internal SATA RAID 0 / AJA Kona LHe / latest revisions of OS X 10.5 and FCP 6, all updates applied
    I’ll try to post some examples on my website when time permits.
    Chris Borjis replied 18 years, 2 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    July 1, 2008 at 5:28 pm
    Take those clips from Combustion into Cinema Tools and conform them to 23.98 (which will then really conform them to 23.976).
    From here on out, make sure to render your 23.98 graphics @ 23.976 out of Combustion.
  • Alan Okey
    July 1, 2008 at 5:32 pm
    Jeremy, thanks for the quick response. I’ll try this ASAP.
    Is this a known issue that I somehow missed when searching the forums?
  • Jeremy Garchow
    July 1, 2008 at 5:33 pm
    [Alan Okey] “Is this a known issue that I somehow missed when searching the forums?”
    Apple really means 23.976 when it says 23.98. If you have created anything @ 23.98 and not 23.976, it’s the wrong frame rate. It’s not an issue, but rather an honest mistake.
    Jeremy
  • Alan Okey
    July 1, 2008 at 6:05 pm
    [Jeremy Garchow] “Apple really means 23.976 when it says 23.98. If you have created anything @ 23.98 and not 23.976, it’s the wrong frame rate. It’s not an issue, but rather an honest mistake. “
    Interesting theory, but I have never run into this problem with 24p SD projects using 23.98 as the output frame rate from Combustion, nor do I have the problem in non-DVCPRO HD high def sequences.
  • Jeremy Garchow
    July 1, 2008 at 6:44 pm
    Than you are lucky as I (and others on this very list) have experienced this with both HD and SD @ 23.98 vs 23.976. I have seen it with AE, though and not Combustion. And also I have seen it in Quicktime. Only on rendered material and not through captured material (as that has the proper frame rate of 23.976)
    Jeremy
  • Chris Borjis
    July 1, 2008 at 8:01 pm
    [Alan Okey] “Interesting theory, but I have never run into this problem with 24p SD projects using 23.98 as the output frame rate from Combustion, nor do I have the problem in non-DVCPRO HD high def sequences.”
    Jeremy is right, I’ve done this before with DVCPRO-HD 720 24P that originated from JVC HD100 24p footage before 24p was supported.
    You had to transcode it with mpeg stream clip and the frame rate MUST be set for 23.976 or you have problems.
    Wouldn’t it be great if we lived in a world without the need for all this workaround hooey?
