Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD 720p Export Settings for Compressor
Posted by Derek Tow on March 29, 2010 at 4:26 pmHey there… I’ve searched for this on the forum but didn’t really find the answer – though I’m sure it’s an old issue.
I am working in a DVCPRO HD timeline that is 960×720. When I send it to Compressor – I’ve had to manually change the pixel aspect ratio to 1280×720 square pixel to get back to widescreen.
Is there a better way to do this? Am I missing something?
Chadwick Shoults replied 16 years, 5 months ago 5 Members · 9 Replies -
Chris Borjis
March 29, 2010 at 5:10 pmDerek what is it you are trying to do with compressor?
is this for a dvd?
Derek Tow
March 29, 2010 at 5:24 pmI am needing a high res HD QT file to hand off to clients.
I will also burn it to SD DVD letterboxed.
Shane Ross
March 29, 2010 at 5:37 pmWhat are you compressing them TO? What CODEC? High res HD files tells us nothing. Your clients, unless they have FCP, or a DVCPRO HD decoder, will not be able to see the native DVCPRO HD files. And if you are converting to another format, then that format SHOULD allow for the proper dimensions.
What is the purpose of the exports? What codec? SPECIFICS please.
Shane
Read my blog, Little Frog in High Def -
Derek Tow
March 29, 2010 at 5:55 pmI am using the QT H.264 codec. When I use standard Compressor QT H.264 settings, it gives me a 960×720 aspect ratio QT file.
My work around – manually changing settings to 1280×720 square works but is there a better way?
Shane Ross
March 29, 2010 at 5:56 pmDo that once. Save it as a custom setting. Then apply that custom setting to the other clips.
Shane
Derek Tow
March 29, 2010 at 6:03 pmThat works but the processing out of Compressor takes four+ hours for a nine minute video. Using standard settings it only takes about 45 min. I was hoping there was a faster workflow than this work around.
Thanks for any advice – outside of buying a faster box.
MAC PowerMac7,3
OSX 10.4
8G -
Derek Tow
March 29, 2010 at 6:10 pmAnother option I tried was to nest the 960×720 sequence into a 1280×720 sequence in FCP before exporting. This worked but again – render time was four+ hours.
It seems to me that there is an unnecessary step I am taking somewhere…
Derek
Ernie Santella
March 29, 2010 at 6:11 pmYou can export right out of FCP to H.264. Just use ‘Export-Using Quicktime Conversion’ under File. Then, select your quality/frame size/frame rate etc. I do this all the time and it looks excellent.
Chadwick Shoults
March 30, 2010 at 6:29 pmMake sure your frame controls tab setting is off in compressor as well.
