Activity Forums Apple Final Cut Pro Legacy DVCPro HD 3:2 pulldown
  • DVCPro HD 3:2 pulldown
    Posted by Devin Clarke on April 14, 2009 at 7:45 pm
    Does anyone know how to solve and interesting pulldown problem?
    I have a HDV converted to DVCPro HD file in Final Cut. Its 29.97fps and I need to convert it to 23.98. It was captured through a third party device in a non controllable setting. The original clip has timecode and start stop points. But the captured clip, is all one file.
    Every time I set the clip to Reverse telecine a box comes up
    ‘This clip is not recommended for reverse Telecine. there are 524 dropped frames.’
    The setting I’ve used in Cinema tools are Conform 29.98 to 29.98
    that seems to help the errors but there are still lots of dropped frames.
    Then Reverse Telecine
    Capture mode: Field1 -Field 2
    Fields: Style 1 AA
    File: New Smaller
    Frames: Conform 23.98 with the standard upper/lower box enabled.
    I have a Macbook Pro 2.5 Intle Core 2 Dro, 4 GB Memory, OSX 10.5.6
    Cinema Tools 4.0.1, FCP 6.0.5
    Thank you for taking the time to read this! if you have any questions please feel free to ask.
    Devin Clarke replied 17 years, 5 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    April 14, 2009 at 7:54 pm
    What format is the clip, I assume 1080i? Are you sure it was shot 24p with pulldown? How was it captured?
    Jeremy
  • Devin Clarke
    April 14, 2009 at 8:10 pm
    Hi thanks for responding!
    Yes the clip is 1080i. It was shot on a XL H1 in HDV 24f mode. When I move frame by frame though the clip i get 2 interlaced, 3 progressive frames repeating, at least I think thats what I’m looking at. 2 fields are mixed together in the ‘interlaced’ frames, no fields mixed in the ‘progressive’ frames. Not really sure what to call it. sorry
    It was captured in one cilp for the whole tape, through a Motu V4 HD box – (https://www.v4hd.com/) converting the HDV signal to DVCPro HD at 29.97fps.
    Devin
  • Jeremy Garchow
    April 14, 2009 at 8:16 pm
    OK. I would try and use the reverse telecine option in Compressor.
    Jeremy
  • Devin Clarke
    April 14, 2009 at 8:23 pm
    Thank You
    I’ll try it too.
