Activity Forums Panasonic Cameras DVCPro HD @ 25fps workflow issues
  • DVCPro HD @ 25fps workflow issues
    Posted by Rich Harrison on November 2, 2005 at 9:22 am
    Hiya,
    i have a client in Canada who has shot DVCPro HD – 720p60 – flagged @ 25fps to make it viable for a PAL market. He’ll be ingesting via a Kona 2 card. None of the presets included with FCP and the Kona card take this frame rate/work method into account. I’m happy to edit the presets but need guidance to ensure the project runs smoothly and correctly. Can anyone help?
    Rex
    Walter Biscardi replied 20 years, 10 months ago 2 Members · 1 Reply
  • Walter Biscardi
    November 6, 2005 at 11:48 am
    [rex205] “None of the presets included with FCP and the Kona card take this frame rate/work method into account. I’m happy to edit the presets but need guidance to ensure the project runs smoothly and correctly. Can anyone help?”
    You just need to make a custom setup as the Kona 2 can capture at just about any frame rate.
    Got into your Audio / Video Settings – Capture Setting tab.
    Choose the AJA 23.98 DVCPro HD Varicam preset and select “Duplicate”
    When it opens up, simply change the frame rate from 23.98 to 25.
    Save it as a 25 DVCPro HD Varicam setting.
    There you go. This will capture in the DVCPro HD codec at 25fps through the HD-SDI input on the Kona 2.
    You can do this to change the frame rate for just about any captures via the K2.
    Walter Biscardi, Jr.
    Now editing “Good Eats” in HD for the Food Network
