Activity Forums Apple Final Cut Pro Legacy DVCPro footage captruing
  • DVCPro footage captruing
    Posted by Peter Dewit on October 30, 2006 at 9:05 pm
    I’m capturing some DVCPro25 using a DSR-1500 footage through SDi on a KONA 2 Card. I’m using the SDI 8-Bit to DV preset to capture. When the footage comes in it looks perfect when it is pausied. However whne I try ot play it back the footage looks blurry and muddy almost like I captured it at low resolution. What is set wrong that could cause tis problem?
    Peter Dewit replied 19 years, 10 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    October 30, 2006 at 9:32 pm
    How are you viewing the playback?
    You must only judge QUALITY by using an external video monitor, and not the Canvas image on the computer screen.
  • Shane Ross
    October 30, 2006 at 9:41 pm
    Shane’s Stock Answer #2: Blurry playback
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL NTSC MONITOR, OR AT LEAST A TV.
    1. Disable overlays on the canvas
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline
    https://docs.info.apple.com/article.html?artnum=24787
    Video playback requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or NTSC monitor routed thru your camera or deck.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Peter Dewit
    October 30, 2006 at 9:49 pm
    My mistake it seems that my RT settings were changed without my knowledge. Thanks for your help though
