Activity Forums Apple Final Cut Pro Legacy DVCPro capture problem
  • DVCPro capture problem
    Posted by Anne Holst on February 13, 2009 at 5:04 pm
    Hi there,
    I’ve got a Panasonic VHX200 DVC Pro camera. I’m trying to capture from tape via Firewire into FCP in DVCPro format. When I press capture, it records for 2 sec, then stops with the comment: Problems reading material on tape. When I try to capture in DV Pal Anamorphic, it works fine. Can I have captured in the wrong format or what have a not done correctly?
    Anne.
    Nicole Haddock replied 17 years, 7 months ago 2 Members · 1 Reply
  • Nicole Haddock
    February 13, 2009 at 6:51 pm
    Well, the HVX200 only captures DV25 onto tape. Run the easy set-up for DV-NTSC (or PAL if that’s what you’re shooting) and you should be able to ingest. Only the P2 cards can record DVCPro and DVCProHD.
