Activity Forums Adobe Premiere Pro dvcpro capture halfway successful
  • dvcpro capture halfway successful
    Posted by Miss2z Miss2z on June 1, 2007 at 3:02 am
    You can’t capture DVCPro footage in Premiere Pro, I’ve learned. That’s a bummer. However, I was trying it through the firewire when it was unsuccessful. So I tried it through S-Video, taking it through a transcoder box that then was connected to my computer with a firewire cable. And it worked! However, I’m not able to get a timecode read in the capture window, nor am I able to control the deck, even though “Device Control” is on in the capture window. Is there a creative way to get that timecode in there so I can not only get the footage in there, but also the timecode?
    miss2z
    Miss2z Miss2z replied 19 years, 3 months ago 2 Members · 2 Replies
  • Rhewitt
    June 1, 2007 at 3:54 am
    Err, no. Once you go to the analogue realm, you will lose machine control and time code. All these require direct firewire connection to your VTR or camera.
  • Miss2z Miss2z
    June 1, 2007 at 4:08 pm
    Duh. I just thought of this . . . I can set it up to see the timecode on my monitor. Voila! Problem fixed!
    miss2z
