Activity › Forums › Apple Final Cut Pro Legacy › DVCam to SDI
  • Posted by Damian Dexter on September 25, 2005 at 9:37 pm
    I use FCP4 and edit a 30 min magazine programme shot on DVCam. It gets broadcast via an XT EVS. I transfer the footage using the SDI output on a DSR2000 using embedded audio. When viewing the broadcast I get some strange effects on dissolves and arced footage which has gone from 16:9 to 4:3. The picture appears to strobe or judder really badly but only on these elements of the programme. Does anyone have any ideas please.
    Damian Dexter
    Graeme Nattress replied 21 years ago 3 Members · 2 Replies
  • David Battistella
    September 25, 2005 at 10:23 pm
    if you are staying in DVCAM codec then I would say what you are seeing is compression artifacting inherint in 5:1 compressed DVCAM material. If you were to online this SDI footage at ten bit uncompressed you might not see this.
    David
  • Graeme Nattress
    September 25, 2005 at 10:27 pm
    Could be some kind of field order issue. Best thing is to pull the boradcast back into your NLE and examine frame by frame to see what’s happening.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
