DVCAM for broadcast SD television. Opinions please.
Hi all,
For those of you that have successfully broadcast your work over the airwaves to television homes across America, let me hear from you. I’ve just recently been a part of a television show that used the following workflow…
Source captured with Sony DSR-500 with YJ18x9 lens (DVCAM)
Footage captured with DSR-1500A via Firewire into Final Cut Pro, edited in NTSC/DV
Mastered to Betacam SP via component cables to deck from DSR-1500
Uploaded via satellite uplink for stations to weave into programming schedulesThe resulting broadcast image looked horrible to me. Grainy, noisy, just really lousy. So here’s the opinion part. Which part or parts of that signal chain was the biggest detriment to the end product?
I realize that Digibeta or DVCPRO50 would be a better source format.
I realize that a better lens may give a clearer image.
Editing in an uncompressed codec for post would clearly be better.But in order of priority, where is the biggest difference seen? My guess is in the originating source format.
Thanks for your input.
TimTim Snider
Deja View Media, Inc.
