Activity › Forums › Apple Final Cut Pro Legacy › DVCAM deck auto recording at 44.1KH when sequence at 48
  • DVCAM deck auto recording at 44.1KH when sequence at 48
    Posted by Cateleven on December 7, 2007 at 10:12 pm
    I just love DV tapes, always getting surprised! I am outputting from a Final Cut Pro sequence set at 48 k to a Sony DVCAM deck (DSR30) usint a Sony DV Cam tape. When it records, the deck auto selects 44.1 as my audio data rate. The deck is supposed to record to whatever the standard of te tape is…I know DVCAM tapes can record at 44.1. But, shouldn’t it record 48 k when my sequence is that? Also, when I put a regualr DV tape in, it records to 48k automatically. Anyone know about a menu setting I might be missing here?
    Rafael Amador replied 18 years, 9 months ago 4 Members · 6 Replies
  • Walter Biscardi
    December 7, 2007 at 10:22 pm
    On our Sony decks, the audio can be changed in the Menu to 32, 44 or 48. I’m thinking you might have that set to 44.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Cateleven
    December 7, 2007 at 10:26 pm
    Thanks for quick reply Walter. I only see 48 and 32. And in the manual it says “The VCR automatically records in the same audio recording mode as the source tape”. I have the deck set to 16 bit–still get 44 on that.
  • Rafael Amador
    December 8, 2007 at 3:03 am
    This is the first time in my life that I hear about DVCam recording 44.1 Khz.
    I haven’t see that in any device and I haven’t found no reference about in any SONY document.
    Only 32 and 48.
    Rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Cateleven
    December 8, 2007 at 3:25 am
    I hear you my brother! That’s the speech I gave the engineer who was looking at my tape at
    the studio I delivered it to. So I went home and did a test. Sure enough, I output to the DVCAM tape with no errors from a 48k sequence. When I re-digitized that same tape into the same FCP project I got an error, after digitizing that said tape sample rate different than project. And the deck said the audio data on the new record was 44.
    My new theory is I have a deck has a bad chip or my tape stock is old. I’m gonna try a different type of DVCAM tape-the newer ones that are HD. I’ll post results if that works–in case someone else runs into same problem. Thanks for answering anyway!
  • Thaxter Clavemarlton
    December 8, 2007 at 4:52 am
    I wouldn’t suspect a tape issue.
    Tape has nothing to do with sample rates.
  • Rafael Amador
    December 8, 2007 at 5:54 am
    The weird thing is that you get 44.1.
    I mean, if there is any malfunction would be possible that you get a random data-rate, but is curious that, although the data-rate is wrong, you get a standard one. The DVCam processor should know nothing about 44.1 Khz.
    Rafael
