Activity Forums VEGAS Pro DVCAM Audio issue in Vegas
  • DVCAM Audio issue in Vegas
    Posted by Mark Moss on May 17, 2007 at 4:12 am
    When I capture a DVCAM tape through firewire, Vegas only records channel 1 (which happened to be the cam mic) I need channel 2. My audio file only shows channel 1 as mono, yet, when I put a previously recorded regular mini dv tape in, both channels of audio are recorded.
    I know there are 2 good channels of audio on the DVCAM tape because I checked it.
    Any help is appreciated.
    Mahesh Upadhyaya replied 19 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mark Moss
    May 17, 2007 at 3:26 pm
    Anybody? Surely someone had this problem before. The VCR is a JVC BRDV-3000. Any help would be appreciated.
  • Edward Troxel
    May 17, 2007 at 3:39 pm
    I’ve heard of some cameras that record the second channel on 3/4 instead of 1/2. Maybe yours is one of them. Try Scenalyzer Live to capture the secondary audio.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    May 17, 2007 at 3:45 pm
    What camcorder was used to make the original recording?
    Try using Scenalyzer (a demo version is available) for the capture and see if that works for you.
    It’s been known to work when VidCap fails at seemingly simmple tasks like this 🙁
  • Mark Moss
    May 17, 2007 at 8:45 pm
    I took your advice and tried another capture. This time I used the DV Capture that was stock on my Sony computer. During the capture, I could hear the “good” channel, so I thought I was in the clear, but once the video was captured and I loaded the file into Vegas, it still gave me the camera mic channel in mono. I can try Scenalyzer if you think that might make a difference. It seems to be a problem with capturing DVCAM.
    Thanks for all of the help
  • Mike Kujbida
    May 18, 2007 at 10:08 am
    It’s not a DVCAM problem but a camcorder problem.
    That’s why I asked you for your make/model.
    Also, did you check out the suggestion Edward made?
  • Mark Moss
    May 18, 2007 at 4:48 pm
    I switched the VTR from 1/2 to 3/4, and it made no difference in capture or playback. The Camcorder is a Sony DSR 200…… Not one that I normally use. I don’t have the camcorder, otherwise I would try playback through it.
  • Edward Troxel
    May 18, 2007 at 6:32 pm
    Please just try scenalyzer live and have it also capture the secondary audio channel.
    Edward Troxel
    JETDV Scripts
  • Mahesh Upadhyaya
    May 18, 2007 at 7:45 pm
    Here’s a reply I posted loooong time ago
    Vegas does not like certain DVCAM cameras. If an external mic is used in one or both channels, then Vegas captures the audio stream from that tape as left (mono) only. It does not matter what player is used for capture. The 2 cameras mentioned in this post are Sony PDX10 and DSR200.
    Complete thread is at
    https://forums.creativecow.net/readpost/24/478326?&archive=T
    As Edward says, easiest solution is use scenalyzer live.
    I have used that marvelous programme for last 3 years and no probs.
    Hope that helps.
    Regards
    Mahesh
    https://www.crestvideo.co.uk
