Activity › Forums › Adobe After Effects › DVC-WOAH HD
  • DVC-WOAH HD
    Posted by Nicholas Toth on August 7, 2006 at 12:42 pm
    Hey guys. Just got some footage off a HVX-200, off the P2 card. Its a 720/60p quicktime file, and it will open in After Effects, or FCP. However quicktime does not like the file. Do I need a codec to open this in quicktime? I just can’t seem to figure it out.
    I know its an AE forum, but I’m usually posting here and I didn’t know where else to ask.
    Jon Walker replied 20 years, 1 month ago 3 Members · 6 Replies
  • Walter Biscardi
    August 7, 2006 at 1:28 pm
    If you go into the articles on the Cow, do an author search on Shane Ross. He did a whole P2 workflow article.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
  • Jon Walker
    August 7, 2006 at 1:31 pm
    If you are using OSX 10.3 or above the HVX200 footage will work natively without any codec installation. If your version of Quicktime is older than version 7, you might run into problems. I’ve had no trouble with HVX200 footage and I’m running Quicktime 7 so that may be your issue. I wouldn’t think if you can view it in FCP you’d be having problems. Try trashing your Quicktime preferences or upgrading your version and see what that does for you. Is your issue an export issue? Will it not play once you’ve exported out from FCP or AE?
  • Nicholas Toth
    August 7, 2006 at 3:38 pm
    Its strange because in FCP it will play, and it will play in AE, but it just won’t play in quicktime.
    I’m using quicktime v7.1.2 pro, in os 10.4.7.
  • Jon Walker
    August 7, 2006 at 3:40 pm
    That is strange. Will it play after it has been exported from AE or FCP?
  • Nicholas Toth
    August 7, 2006 at 5:07 pm
    That I don’t know. It was burnt to a DVD and sent to me.
    I think I’ll just convert through compressor.
  • Jon Walker
    August 7, 2006 at 5:10 pm
    That would probably be the safest way to go. I have never had anything brought in from HVX200 via DVD but I have done it straight from the camera and had no problems playing it back. If the compressor conversion doesn’t work, you might check Panasonic’s web site for any software or plug-in downloads that might help. Good luck.
