Activity › Forums › Apple Final Cut Pro Legacy › DVC ProHD in Final Cut
David Roth weiss
May 23, 2011 at 8:36 pmBoth should still be good enough for DVCProHD. Is the G-Raid full or close to full?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Brad Williams
May 23, 2011 at 9:10 pmBoth my G-Raid and Lacie are half full. Here is the crazy thing. If I pull one section of video to the G-Raid or Lacie, the playback artifacts, but straight out of the FS-100 when I open a Quicktime file, no artificating. really puzzling.
John Pale
May 23, 2011 at 11:33 pmSo this happens with any drive connected via eSATA?
Can you try a different eSATA cable? If the problem persists…
Can you try Firewire or FW800?
If the problem goes away with Firewire, then your eSATA card (or its driver) is the problem.
Brad Williams
May 23, 2011 at 11:39 pmYes, with all E-Sata drives. I will try FireWire in the morning to see if it changes.
Brad Williams
May 29, 2011 at 8:20 pmUpdate on this. With rendered video to my Mac Pro, the QuickTime playback is fantastic with no issues. When it mistaken to another video venue campus, they are saying it looks like it is skipping frames at times. They said they a half-second issue, not stopping but jerky or hesitant in playback. The video is played out of a 3.06 iMac running DVI out to a DVI extender. Cat 5 . Could it be a video card issue on this?
