Activity › Forums › Apple Final Cut Pro Legacy › DVC Pro VTR and Edit To Tape
  • DVC Pro VTR and Edit To Tape
    Posted by Chris Tompkins on July 7, 2005 at 8:19 pm
    I have a DVC Pro VTR AJ-D650 – been a work-horse. Using the AJA IO LA I have a RS-422 cable connected and the deck works fine for capture. I have machine control with FCP. Capture is fine, Batch capture is fine. I have the device control set to Panasonic Rs-422.
    When it comes to “Insert Edit” it is not available. I have tried changing settings within the deck setup menu and to no avail. When I switch the cables to the Beta deck (1800) insert edit becomes available and works fine. Has anyone gotton insert edit to work with a DVC Pro deck?
    I even switched to a usb to serial adapter for the machine control and got the same results. Repaired Permis, trashed prefs. As a last ditched effort to get something done I went into “Edit to Tape” mode with the beta deck hooked up, then switched the cables back to the DVCPro deck and it worked.
    anybody?
    Thanks.
    Chris
    G5 Dual 2.7, 4.5 GB ram FCP 4.5 OS 10.4.1
    Chris Tompkins replied 21 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 7, 2005 at 11:55 pm
    The deck itself has to support insert edits… I bet it doesn’t… (1800 certainly does support it so that’s why it works for you there). Look in the Deck’s manual?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Chris Tompkins
    July 8, 2005 at 2:36 pm
    Thanks Jerry. Yes the deck does support Insert edit. Been doing it for years with my Media100. Which is now sitting shamefully in the closet.
