Activity Forums Apple Final Cut Pro Legacy Dvc pro Problem in Final Cut Pro
  • Dvc pro Problem in Final Cut Pro
    Posted by Jas Sekhon on October 5, 2007 at 9:35 am
    Hi This is Jaspreet i am currently using a G5 quad , apple cinema display 23″ ,Final cut pro 5.1.4, decklink extreme (6.4 driver) , and Panasonic AJ-SD755 player/recorder. My problem is that while i am trying to playback dvcpro tape from the player it plays on the broadcast monitor, but in the capture window of final cut pro it shows color bars but below it shows VTR ok. I updated the decklink driver from 5.8 to 6.4 the first time i came across this prob. but that didnt solve my issue ok than i tried to take input through composite mode as i was doing it initially through SDI still there’s no breakthrough. I even checked it through firewire mode still it doesnt solve my prob. 1 more thing i wud like to add there is no such prob while capturing miniDV .
    I also tried to delete preference files of FCP , created a new user even these things don’t help so anybody here who can help me get through this issue as 70% of my work is going to be on DVCPRO i wud be very grateful…..for any sort of advice….
    Tom Meegan replied 18 years, 11 months ago 2 Members · 2 Replies
  • Tom Meegan
    October 7, 2007 at 10:51 am
    Start a new project.
    Go to Final Cut Pro > Easy setup…
    Choose one an easy set up that matches your source material and capture method.
    Click OK.
    Save the project with a descriptive name.
    Open the capture window.
    Any luck?
    Tom
  • Tom Meegan
    Choose an easy set up that matches your source material and capture method.
    Click OK.
    Any luck?
    Tom
