Activity Forums Apple Final Cut Pro Legacy DVC Pro HD – video is black
  • DVC Pro HD – video is black
    Posted by Luke David on May 1, 2006 at 4:01 pm
    I am trying to bring in some DVC Pro HD and here is the problem; I am going through a AJA Kona 2 card and the easy set-up is set to “AJA KONA 2 – 720p 59.94 DVCPro HD”. The device control and capture presets are all set for a panasonic deck which I am using. When screening and logging the tape it is audible and visible and in sync, it is also audible, visible and in sync while capturing. However, when the clip is captured and I play it down, there is audio but the video is black. Help please thanks.
    Walter Biscardi replied 20 years, 4 months ago 3 Members · 4 Replies
  • Walter Biscardi
    May 1, 2006 at 4:04 pm
    Ensure that you’re running at least FCP 5.0.3. If you’re coming in via SDI through the Kona board, FCP had issues turning your captures into Subclips. What you had to do was delete all those subclips from your Browser and import the corectly captured clips from your harddrive.
    FCP 5.0.3 and 5.0.4 Apple finally corrected this issue.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Gary Adcock
    May 1, 2006 at 4:07 pm
    [walter biscardi] “Ensure that you’re running at least FCP 5.0.3. If you’re coming in via SDI through the Kona board, FCP had issues turning your captures into Subclips. What you had to do was delete all those subclips from your Browser and import the corectly captured clips from your harddrive.”
    this also appears when the deck is not set for the proper input settings.
    Check to see that the deck is showing a lighted 720p on the front of the deck under the audio controls.
    Studio37
    HD & Film Consultation
    Chicago, IL
    gary@studio37.com
  • Luke David
    May 1, 2006 at 4:15 pm
    It was the version #….Thanks Walter
  • Walter Biscardi
    May 1, 2006 at 4:26 pm
    [lcdavid] “It was the version #….Thanks Walter”
    glad I could help. that was a very big bugaboo for about 6 months.
