Activity Forums Apple Final Cut Pro Legacy DVC Pro HD to Standard Def
  • DVC Pro HD to Standard Def
    Posted by Frank Muldoon on April 29, 2008 at 10:58 pm
    How do I bring a DVC Pro HD clip into a FCP 720×486 project to take advantage of the larger format area. I want to be able to pan and scan or go to close-up shots using the extra HD size.
    FCP seems to reduce the size of the HD on import even though the clip info reads 960×720. Do I have to take the footage into After Effects and render out “shots” for the standard def project?
    David Roth weiss replied 18 years ago 2 Members · 3 Replies
  • David Roth weiss
    April 30, 2008 at 1:13 am
    When dropping an HD clip into a SD timeline, FCP will scale it down and letterbox it. You can then double click on the clip in the timeline, load into the viewer, and scale it up and animate as you wish including keyframing moves. Does this make sense?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Frank Muldoon
    April 30, 2008 at 1:27 am
    It seems that the clip is not really full resolution. In the basic motion tab when I increase the scale to 100% it is only as tall as the standard 486 frame. 100% should make the clip larger than the frame, right?
    Also what would the calculation be to get pixels up to a 1:1 ratio. That is, not blown up to distortion but as big as possible at full resolution.
  • David Roth weiss
    April 30, 2008 at 3:12 am
    Frank,
    I’m not certain why blowing-up your HD source to 100% in the Motion tab doesn’t make your video larger than the 720×486 frame size, it certainly does here. Try checking in the “distort tab” to make certain distort is set to zero.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
