Activity › Forums › Apple Final Cut Pro Legacy › DVC Pro HD digitized, Finishing SD
Posted by James Nolan on November 20, 2006 at 3:19 amHoping for Suggestions–
I am working on a project where DVC Pro HD tapes were shot with a Varicam 720p23.98. The final master requirement is digibeta. IJames Nolan replied 19 years, 10 months ago 3 Members · 3 Replies -
Walter Biscardi
November 20, 2006 at 3:21 am[James Nolan] “I then created a separate project with a Kona LH NTSC 10 Bit Uncompressed 29.97 setup and dragged the HD clips into the project. The HD footage plays well, except the interviews
Shane Ross
November 20, 2006 at 3:45 amAnd I have found that capturing varicam 720p24 i am always off sync by two frames. audio hits two frames BEFORE video. SO I have to slip the audio two frames to get it in sync. We have some footage that is off by 8 frames, but the norm is 2 frames.
Capture and edit the whole shot at 720p24, then downconvert when you output, as Walter said.
Shane
Littlefrog Post
http://www.lfhd.net -
James Nolan
November 20, 2006 at 4:15 amThanks, guys. The master is 4:3, so I guess I’ll set the Kona LH Control Panel to Downconversion – Crop and keep the client monitor on overscan?
Any other considerations or am I good to go?
