Activity Forums Adobe After Effects DVC Pro HD codec? How to import to AE?
  • DVC Pro HD codec? How to import to AE?
    Posted by David Del on October 5, 2007 at 2:49 am
    I have a file that is a .mov – DVCPro HD (Quicktime info), but I can’t open it. What am I missing? Is there a codec that I need to open this on my machine?
    David Del replied 18 years, 11 months ago 3 Members · 4 Replies
  • Steve Roberts
    October 5, 2007 at 1:12 pm
    Yes. Search the COW for “DVCPRO HD” and “codec” and you’ll find more info.
  • Harry Frank
    October 5, 2007 at 1:17 pm
    The way it has been explained to me is that this codec is only licensed by Panasonic to a handful of applications, like Final Cut, Vegas, etc. Premiere doesn’t seem to be in the “in crowd”.
    So, the only way to be able to have and use the codec is to have a host application that uses DVCPro HD.
    This is a real bummer, as I seem to have to buy Final Cut just to use my client’s source files. Even Avid has had publicly available software codecs going all the way back to ABVB. Hopefully this will change some day, but for now, you’ll have to find a way to convert the files.
    Consequently, this is how I found out that using the H.264 codec with source footage in AE CS3 will make for a miserable experience.
    Harry J Frank
    Freelance Motion Designer
    graymachine.com
  • David Del
    October 5, 2007 at 1:21 pm
    Strange because I have Vegas and it doesn’t open up in it. I get an audio stream in Vegas, but no video.
  • David Del
    October 6, 2007 at 10:34 pm
    The only issue is that I am not getting paid for the work I am doing that requires this codec. And although the codecs are not the expensive, I might never use them again in future. I am trying to figure out a way to work with this footage that will accommodate that.
