Dvc Pro HD codec option not showing when exporting mxf
Hi all,
I need to deliver a video following these settings:
Format: MXF
Profile: OP-1a
Codec: DVCPRO HD
Interlaced
25fps
Audio: 8 ch (1,2,3,4 are the full Mix, 5 and 6 Audiodescription, 7 and 8 M and E)I have just downloaded latest version of Final Cut X Pro, 10.3.4 and was about to export the mxf file directly from the timeline,
but somehow the DVC Pro HD codec is not showing on the codec section, only the full ProRes family, AVC Intra 50, 100 and 200,
and XDCAM HD 35 and 50 mbps. Also I have installed latest version of Video Pro Formats. The thing is the codec is showing in
Compressor, but when I try to export the QT multitrack file with the audio channels configuration as requested, I only get
a mxf file with all 8 eight audio channels mixed into the first 1 and 2 channels, and then silence in channels 3,4,5,6,7 and 8.So I am stuck here, a little help would be very much appreciated…
